joshuajim's avatar
joshuajim
Explorer II
Apr 12, 2015
Defective pendant?
I installed a PD9260 with pendant about 2 years ago. Recently I have noticed that the "change mode" button on the pendant has stopped working. Press and hold or press repeatedly, it does not change mode. Has anyone else experienced this issue?
  • Try unplugging and plugging back in as suggested above. If that doesn't work, take pendant apart and check switch. Its just a little piece of tin that might have gotten dirty, or bent out of shape.
    Borrow a friends to try, if you have a bad pendant, get a new one on e-bay $12.00.
    Doug
  • Bobbo's avatar
    Bobbo
    Explorer III
    Maybe a bad connection. Try unplugging the pendant and plugging it back in.
  • I had a 45 amp converter with pendant on my MH. Never had any trouble with it, but I have sold the motor home, so I can't even go look to see if I could help. Good luck with your quest to answer the question.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
