Joe417
Aug 19, 2018Explorer
#3. I did this on a TC a couple of years ago. It turned out very good.
You don't need to score the plywood. 1/4" or 5mm is too thick. I used 1/8" door skin luan and it will bend to follow the contours nicely. The lower curve on the one I did was about an 18" radius.
If you put it back correctly and maintain the yearly resealing it should last a long time. There are many oldies on the road with this type of construction.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Oct 16, 2022
