dougrainer wrote:
JaxDad wrote:
Glad you found the actual problem instead of just throwing silly wasted parts at it.
So much for the “ONLY” solution........
The main reason I won’t go to the stealerships is for exactly that reason, there’s no THINKING about the problem and finding the solution, it’s just throwing parts at it because a book or computer said to do that.
Thankfully the only place where such foolishness does NOT exist is in aviation, which given the price of parts is a VERY good thing.
According to the description the OP made, Heavy acceleration, The problem was the vacuum was used up, which IS a common problem on Ford Chassis vacuum supply. The difference is YOU don't trust dealerships, that is fine. But you come to me and then you pay me $150 an hour to find a supposed vacuum leak, then I find some leak and fix it $300 later. Then you come back and tell me the problem still happens on full acceleration, you then pay me MORE. So, a customer comes to me and based on MY EXPERIANCE, I charge him $150 install plus the $75 for the Vacuum pump and at $225, he is fixed EVEN IF HE HAS A SMALL VACUUM LEAK. The 12 volt pump will overcome any supposed vacuum leak. Lets wait and see if the OP's problem is fixed on heavy acceleration. Doug
Doug, your thinking on how to "diagnose and fix" IS exactly the way most all "dealerships" approach repairs now days.
It IS quick and fast and the dealership EARNS the money in a hurry.
They don't have REAL troubleshooting and diagnostics training which leads to mickeymouse fixes and just throwing parts at it.
All the time not fixing the real problem, only masking the problem and often ADDING NEW PROBLEMS.
Yeah, I am angry with how repairs went with one of my vehicles, cost me nearly $4K, ten trips later and they NEVER fixed the problem.
I ended up doing Internet searches and FOUND the fix, a can of carb cleaner and a rag.. Instead I ended up paying for new fuel pump, new filter, new plugs, new cat.. Then down the road because of other problems I ended up having to change all the O2 sensors which were damaged and finally the other cat which because the dealer didn't fix but add other problems..
Yeah, $4K and dozens of trips to dealer, lost use of that vehicle for months, couldn't depend on it...
