Almot
Feb 15, 2014Explorer III
Bumpy, I hear your pain of dealing with caulking guns. But if you need a caulk-ish substance, you have no choice but to use a gun, or a smaller squeeze-tube which apparently is not available with Dicor. And then spread it over a larger surface with a putty knife if you have to, but do it quickly because the surface starts "skinning" after a few minutes and then it doesn't adhere well to the parts that you are working on.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
