Bumpyroad
Feb 20, 2014Explorer
DiskDoctr wrote:Bumpyroad wrote:
This is on a fiberglass roof. might have to invest in a "powered" caulking gun, assuming that those can be fine tuned to put down a steady line. just checked at Home Depot. they have a Ryobi 18 volter for $40.
bumpy
These guns work great! It backs off a bit each time you release the trigger, so it's best to layout what you want and put it on in as continuous bead as possible.
The thickest I've used it with is Blackjack roof cement, which is basically the consistency of tar.
And, yes, you can take it down to a fine bead using the proper combination of gun setting and speed you mmove over the surface. No need to pause or surge for hand pumps ;)
I've owned one for many years and recently changed the batteries to Li-ion
thanks for the user testimonial. sounds like a plan if I can't find the stuff in a can. would like to use a urethane type as that was recommended.
bumpy
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
