- NinerBikesExplorer
pnichols wrote:
smkettner wrote:
I want just a 12v charger if it comes to a new model. Size weight and sound of a Honda 1000 with 50 amp 14.5 volt output. Maybe even a timer to shut down as desired.
I'd just like an inexpensive 30 amp power factor corrected stand-alone 12 volt charger to power via my Honda EX650. Right now I use the little Honda to simultaneously power the stock converter in parallel with a cheap and old Sears 2-10-50 charger set on it's 50 amp setting.
This combination will only pump around 12-15 amps into our coach batteries due to the terminal voltage on the batteries not winding up high enough. Even on it's 50 amp setting, the old Sears charger just cannot raise the batteries' terminal voltage high enough above the output voltage of the converter so that the batteries will draw more. Of course that is also a good thing ... because if the batteries tried to draw more amps from the two charging sources ... the Sears charger might run too hot and go into thermal shutdown or burn itself up.
P.S. I'm curious: What sound from a Honda 1000 would you like while it's putting out it's maximum power? I'd prefer it's 53 dB sound level at it's maximum power - not it's current 59dB sound level at maximum power.
What the EU1000i makes for power at full load, and noise, the EU2000i will do quite easily in Eco mode and loafing along. My MegaWatt 30 Amp PSU will put the grunt on the Eu1000i, when I first charge for 10 to 20 minutes. Run on the Eu2000i, it's bigger brother is not even phased noise wise with the same MegaWatt 30Amp PSU. 48#'s for the Eu2000i. Might be a little more fuel consumption with the bigger motor. But it's quiet where the Eu1000i is making grunting loaded sounds. - JiminDenverExplorer IIThere are a number of inverter generators nearly as loud, as loud or louder than my Champion open frame at 68 db.
- DonnohExplorer
MrWizard wrote:
"quite the athlete"
"Quiet as a mouse"
Pet peeve? - MrWizardModerator"quite the athlete"
"Quiet as a mouse" - smokey_campingExplorerAll company's are always upgrading or replacing models, the only model of late that is NEW to Honda is the 7000is which went from carb to fuel injection! I own the older 6500is and yes it is VERY quite. You can stand next to it running with a load and have a normal conversation. If you want a quite generator no matter the brand get an "Invertor" style any reputable company's inverter will be quite.
- pnicholsExplorer II
P.S. I'm curious: What sound from a Honda 1000 would you like while it's putting out it's maximum power? I'd prefer it's 53 dB sound level at it's maximum power - not it's current 59dB sound level at maximum power. - NinerBikesExplorer
This, and if you can only get 40 or 45 amps instead of 50, and make it 15.3V - 13.6V or have minor Voltage adjustments, for different types of batteries and battery chemistries, so much the better.
Take into account elevation of 7 or 8000 feet for camping, and gas cut with 10% alcohol into what the motor can make HP wise. And a carburetor that won't clog brass jets on 10% gasahol. - pnicholsExplorer IIWe're as usual getting a bit off topic ... but at least staying in the context of Honda and noise:
We used to carry one of these Hondas on the back of our Dodge 3/4 ton van camper. We converted the van into a camper (including upgrading to 60 gallons of fuel capacity) and made a custom rack for the Honda bike. We rode the Honda all over the Utah desert with just me on it, with the DW and myself on it, and once (along the original abandoned Golden Spike rail bed) with myself, the DW, and our dog on it. What a classic - louder than Honda generators, though:
https://www.youtube.com/watch?v=xO2In0s-xZM - MEXICOWANDERERExplorerI remember my old E-1500 belt-driven was a real handfull. And I was 40.
MEXICOWANDERER wrote:
- You shop online
- You read consumer Reports
- You chat in forums
- You sleep on it for weeks
- Finally you are convinced you have purchased the most amiable machine to offend the campground least
Then the brother-in-law of the guy camped next to you shows up...
This is what we felt like in a dry campground a few years back. No one would have noticed the difference of a few Db between this or that generator, each one became part of the group hum.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
