- HuntindogExplorer
woodman1 wrote:
All I'm saying is what the dealer told me. That Dometic said with the newer freon, it doesn't cool as well. Just saying.
Here is the deal.
The newer refrigerents have a higher boiling point. A pot of water boils at 212. No matter how much more heat you apply to it, 212 is the max. The extra heat is carried off as steam or gas.
R22, R410,R12, and R134 work the same way. Except the boiling points in all of them are below freezing. In a refrigerant system the Freon is boiled off at a controlled rate, absorbing heat from the air as it does so. The compressor then compresses the Freon gas into a liquid that is hotter than the ouside temperture so that it can be cooled by it, and then the process repeats.
So any of the Freons are perfectly capable of maintaining a comfortable temp. The hardware components need to be sized correctly/differently due to the different boiling points, but since they are ALL below freezing, they will all work equally. In fact, the ACs are designed not to allow the outlet air temps to get to the freezing point, to avoid icing up, and restricting the airflow.
And yes some new Freons are coming. It seems that they have just discovered that 410 and 134 are bad for the environment....
I say follow the money.
Dupont held the patent on R12. When it ran out everyone was making it and the price dropped to .79 a can. Dupont lobbied congress about the problems with R12, and got it outlawed. The new 134 had a brand name of Suva and was said to be problem free. Guess who held that patent? Dupont.
I never looked at the 22 vs 410 situation, but I bet it is very similar - mark1228Explorer
dougrainer wrote:
This gives YOU a heads up that the "dealer" will say anything. So, how can you trust him in the future? Clarify, did a TECH state this or a "Salesman". BIG difference in where it comes from. Doug
Another factor to consider in cooling the newer units would be if it is going to have a white exterior or something darker like many of the new RV's have. With a darker exterior, you may need more btu's to keep it cool. - TechWriterExplorer
TXiceman wrote:
I love to hear the stupid stories that RV dealers come up with.
Yeah, I think you could fill a book. - C_SchomerExplorerI just cleaned and combed the coils in our 08 Dometic and it's R22. We're changing our obsolete low pressure chillers at work to 134a screws. I hope the gov't doesn't phase it out now. Craig
This gives YOU a heads up that the "dealer" will say anything. So, how can you trust him in the future? Clarify, did a TECH state this or a "Salesman". BIG difference in where it comes from. Doug- MrWizardModerator
woodman1 wrote:
Ordering my new 5th wheel. Dealer recommended 3 a/c on a 39 ft model. They said in 2012 government made them use different freon and it doesn't cool like the older ones, according to Dometic. Anyone hear of problems with them?
The normal Two might do it, but having the 3rd will be good insurance
There are time our 34 ft must have both A/C's on, and is still not quite as cool as we would like, other times one is enough even at 90+
Direction parked, aka broadside to the Sun, shade, hot winds etc..
Play a big part
Many people have a hard time cooling the RV with slides out
The 3rd a/C is a good idea - hypoxiaExplorerVehicles will be changing from R134 to R1234 soon also. I'm sure we'll hear the same stories with it.
- woodman1ExplorerAll I'm saying is what the dealer told me. That Dometic said with the newer freon, it doesn't cool as well. Just saying.
- Bob_LandryExplorerI agree that a BTU rating is what it is. Even if there were some slight difference, the casual owner would not know because he has nothing to measure it with. It gets down to engineering which is beyond the scope of most of us and certainly beyond the casual user.The big difference is the pressures they run at. My R22 units kick off on high head pressure at 425lbs while the R410a units kick out at 575lbs. The suction side runs at almost twice what the R22 units run at and all of that takes some getting used to.
Dometic started building their marine systems with R410a back around 2007, but we are just now starting to see problems with them, probably because of the age of the equipment. That's going to be the norm with any generation of equipment. And that is just a generalization. I have 20-25 year old R22 equipment out there that still have the factory seals on the service ports. - TXicemanExplorer III love to hear the stupid stories that RV dealers come up with. The newer units have R410a as a refrigerant rather than the R22 which was phased out for all new production units. There is no difference in cooling between an older R22 unit and a newer R410A unit. Both produce the same 15,000BTUH.
Now where there was some capacity reduction or poor cooling was in converting an R22 unit over to a new refrigerant blend. New units are designed to operate on the new refrigerants.
Ken
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 22, 2026
