NinerBikes wrote:
And after doing this procedure, on a normal sunny So Cal 70F temp day, will your Specific Gravity show up at around 1.265 pretty consistently  plus or minus .005 or less being preferred?  Because that's pretty much what I expect out of my batteries.
I have an IR thermometer so I take battery temp but I do log air temp too. SG is 1.282 corrected to 70F/21C battery temp. Cells are all within .005. I noticed when the electrolyte gets under 60F/15C, the SG goes up. Right now they're around 1.300. Last year at this time the SG was about the same.
EDIT: I've also noticed that the battery temp can lag air temp if it's been cold the night before. Ex: the last reading I took (a month ago), it was 55F/13C but battery temp was 47F/8C. It was below freezing the night before. I can raise the battery temp up by opening the compartment door. In the summer, they are usually within a couple degrees.
dclark1946 wrote:
Does anyone make a digital hydrometer?
I don't know. I think I looked for one once but don't remember if I found anything. :)
