boogie_4wheel
Aug 07, 2015Explorer
So on dead flat ground (scale) you have ~550 lbs of tire capacity remaining. Get it on the road (crowned) or in a side wind and your are going to shift some weight to the side. I think you are overloading a tire slightly and may be the cause of the failures.
I've had good luck with General tires (I've owned a few set with different tread patterns) but have never run them near capacity.
Go to a different tire size/brand to get a 3450+ tire capacity, or maybe even swap to an 18" wheel for a higher tire capacity.
