Hopefully this setup guide will be helpful.
Receiver Setup: After banging my head against a rock several times trying to reproduce the setup I made these instructions which may help others. Different dish types and TVs required additional setup. Different TV types also meant that the DTV remote would not work both TVs. Dish pointing is not included.
Here are the receiver setup instructions I used when moving the HR24 receiver from home HD to the 18” round portable SD dish for the MH. Note: The HR24 is a dual tuner DVR (connect 2 coax cables) but that is not a factor in the setup.
Home – Slimline 5 Dish and HD Channels
1. Install 2 B-Band Converters and all cords
2. Turn on receiver wait for setup to complete (about 6 minutes).
3. Menu-Settings & Help-Settings-Display-TV Ratio: Widescreen 16:9
4. Menu-Settings & Help-Settings-Display-TV Resolutions: Check all resolutions.
5. Menu-Settings & Help-Settings-Display–Video: On, Pillar Box, Dark Gray
6. Menu-Settings & Help-Settings-Display-Preferences-Guide HD Channels: Hide SD duplicates.
7. Menu-Settings & Help-Settings-Satellite-Repeat Satellite
Setup: Dish setup: Option 4–Slimline 5 02: Multiswitch Dual. To confirm: Menu-Setup-System Setup-Info & Test-More System Info and confirm dish type
MH – Portable 18” Dish and SD Channels Only
1. Do not install B-Band Converters
2. Plug in all cords. Turn on receiver wait for setup to complete (about 6 minutes)
3. Menu-Settings & Help-Settings-Satellite-View Satellite Strength-Satellite 101, final check after aiming the dish
4. Menu-Settings & Help-Settings-Display-TV Ratio: Standard 4:3
5. Menu-Settings & Help-Settings-Display-TV Resolutions: Check 480i only
6. Menu-Settings & Help-Settings-Display–Video: On, Pillar Box, Dark Gray
7. Menu-Settings & Help-Settings-Display-Preferences-Guide HD Channels: Hide HD duplcates. Note: This takes a few minutes to change.
8. The MH Portable dish will not receive/record HD and will display ln not found for HD channels.
9. Menu-Settings & Help-Settings-Satellite-Repeat Satellite
Setup: Dish setup: Option 1 – 18” round dish 02: Multiswitch Dual. To confirm: Menu-Setup-System Setup-Info & Test-More System Info and confirm.
The only practical mounting for the receiver in the MH was vertical in a cabinet and that required the use of a RF remote which the HR24 supports. Switching back to the IR remote for home was tedious since the front panel had to be used to switch the remotes. Before long I purchased a second RF remote to use at home. Each of the RF remotes was programmed to support their respective IR TVs which was another reason for having the 2 remotes. Programming the remote can be found under Menu-Settings & Help-Settings-Remote Control-Program Remote.
Later I added a HD SWM dish to the MH and used these settings for the MH. Note: The MH TV is HD and Widescreen. The HR24 receiver will also operate with the single SWM coax.
MH – HD Dish – SWM Dish and HD Channels
2. Plug in all cords. Turn on receiver wait for setup to complete (about 6 minutes).
Setup: Dish setup: Option 17 Swimline-3S(SWM), 01: SWM, Dual. To confirm: Menu-Setup-System Setup-Info & Test-More System Info and confirm dish type
