We have Direct tv with 2 hd receivers with a 3500 Winegard Satellite dome . It works great and am very happy with it. My only issue with it is whenever I turn the generator on we lose the signal and ...
Stick with 01-18" round for now. However, if you have a SWM setup at home the receiver can be some what particular about changing off that setting despite you manually entering the correct parameters. You do need to get the proper settings and ensure you go into Display and Preferences and set it to Show All Channels (or Hide HD or Show SD) to ensure you can see 231 Food and 231 Food HD. You should be able to watch 231 Food but you will not be able to watch 231 Food HD.
