DustyRooster's avatar
DustyRooster
Disable Dometic Heat pump on AC unit? (for dry camping)
Good morning, All!
I have a question I am hoping one of you can help with.
Purchased a 2015 coachmen class C and unknowingly it has a heat pump integrated with the AC.
This would be good news, if I used campgrounds often.
I boondock quite often, and when the heating circuit sees AC the heatpump wants to run in conjunction with the furnace, as those with heat pumps already know. This is not a good situation when on batteries. The 12v furnace is easily useable all night vs a heat pump firing up and taking the battery down to almost nothing its first run.
How do I disable that "feature" to stop the heat pump from firing when I only want the furnace? Is there a way?
I tried to shut off the breaker of the AC. That does allow the furnace to work without the heatpump, but I have to CRANK UP the thermostat in order to get the propane furnace to fire, and It does not have the 1/2 degree or 1 degree to kick on the furnace alone. So it's like the system "needs" the heat pump for operation.
Any way around this?
Appreciate any input!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ok I'm going to tell you what I did on my RV... First. new the Q!@$!#@$E Furnace control was flakey.. The Front Carrier A/C (I won't bother to tell you to avoid Carrier as they don't make 'em any more for RV's) controlled the Furnace and the Thermostat was part of the A/C Ceiling uint.. Had to use a fan to tame it (Blow air from elsewhere in the RV)
    So I found where the wires ran down the wall (Behind the master control panel logically) and tapped them.... Did not get around to the rest till the Carrier turned into a Coleman without furnace control
    Then I got a simple mercury free mechanical Thermostat from Ace hardware (NO special recommendaton other than i think it was 20 bucks or less) This type uses a bi-metal spring and magnetic contacts (the magnets make it "Snap" open or closed) and wall mounted it.. Unlike the old no longer made Mercury bulb T-Stats this one need not be level. The one I had was heat only.
    Add it with a SPDT toggle switch so you can control the furnace either with the Heat Pump system. or independent and you are golden.
  • dougrainer wrote:
    IF you have the tstat I posted link too. IF you have Fan speed set to Hi or Lo, then IF you have 120 available the roof AC fan will come on. to STOP that you set the Fan speed to AUTO and when on furnace the roof AC fan will NOT run. Doug
    @dougrainer
    This suggestion looks to have worked! Per previous post, the fan was set on "high", and it called the HP for heat assist. Per your suggestion, when I set the fan to "auto", only the propane furnace was called.
    This is the exact behavior I was looking for, and it was just a tstat setting!
    These forums come through yet again!
    Thanks @dougrainer for the solution, and all for the feedback/suggestions.
    -DR
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
