wnjj
Jun 29, 2020Explorer II
time2roll wrote:wnjj wrote:While you are correct... I understand that typically generator gets priority so I believe RVs would remain isolated until the generator was shut down.
The park just doesn’t want every RV in the place to switch back to campground power at the same time when it returns. If people have to manually have to reconnect it spreads the load.
I guess that makes sense in that the “normal” use doesn’t require energizing the relay coils full time, however much like unplugging you wouldn’t have an easy way to know the power was restored. I suppose you could have some circuits that only connect to shore power and/or a tattle tale indicator for shore power.
