RoyB
Aug 01, 2013Explorer III
I am looking at doing something similar here on my OFF-ROAD POPUP camper. My current 85AH standard issue Interstate batteries are ending their life expectancy and I want to get more Battery capacity for my activities. I am wanting to increase my battery capacity because of having high current two radios being used in my truck on occasions along with camping off the power grid.
My interest was to install two each 150AH 12VDC Trojan T1275 on the trailer tongue area and another two each same batteries in the bed of my truck.
I was considering these two layouts...
The two batteries installed in this drawing would be 150AHs each verses the 110AHs as shown..
As you can see my PD9260C 60AMP Converter/charger is located about 5-feet away from the main Blue Sea battery switch for the two 300AH batteries installed on the trailer tongue. The two batteries installed in the back of my truck bed will be around 8-feet away from its 2-conductor trailer connector mounted on the rear of the truck next to my 7-way trailer connection. The 2-conductor trailer cable with plug will be around an additional 8-feet long where it terminate into BLUE SEA battery switch. I am planning on using 4AWG size cables.
This of course will have a longer cable pair feeding the two 12VDC batteries installed in the truck when I am in my camping mode. I will monitor the charging currents when being charged to determine if I am getting my approximate 20 AMPS per battery when being charged.
I have previously been charging three batteries in my setup and the average DC current being drawn was 52-53 AMPS for my then three 12VDC batteries in parallel. I realize when I have have four batteries being charged the total current being drawn will be 15AMPs per battery minus loses in the battery cable lengths.
This is a diagram of my current battery arrangement on my POPUP. I will extend the BANK 2 leads and assocaited batteries to the back of my truck for the new installation.
I always have the capability of charging each group separately using my BLUE SEA battery switch arrangement which will be my PLAN B if it doesn't work out like I want it to.
I was thinking maybe it would be a work around if I used 2AWG battery cable in the longer cable runs to the truck bed but was unable to find a good 2AWG gauge 2-pin connector from etrailer. This would equal the mis-load better perhaps...
Being able to read my DC voltages and DC Currents when doing all of this will tell the story...
Just passing along to show what I will be doing to test out my next battery upgrade...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
