KMLsquared
Aug 01, 2013Explorer
RJsfishin wrote:
Series the 2 distant batts, and bring it back as 12 volts
If you parallel them and bring it back as 6 volts, you will need larger cable because of the lower voltage, or suffer more voltage loss.
And I would use the frame for neg ground, I'd never run 2 cables
Thank you! That's the reasoning I was looking for!
I guess I did forget I have the frame to use as a electrical path. My old truck camper did not.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
