time2roll
Aug 01, 2013Nomad
This is why I like 6v in parallel near and 6v parallel far.
Balance these parallel is easy. Then all must flow through the interconnect wire to create 12v. No imbalance.
If you must wire in series in each place then the close battery should not be grounded except through the other far battery.
Either way all power must flow the entire distance to be balanced.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
