mchero
Mar 08, 2020Explorer
ktmrfs wrote:
and if your going to use cable larger than about 10ga (small wire number) look into a good hydraulic crimper, avaiable on ebay at reasonable prices. especially once you get to cable sizes from 4ga down to #0000.
crimp, cover with adhesive lined heat shrink. All of mine I used welding cable I cut to length, again cable cutters avaiable on amazon or ebay. Since welding cable is usually only available in black, I use red or black heat shrink as appropriate.
I do have a cable cutter that kinda looks like a big pair of pruning shears. I have a cheapo hydraulic crimper from I believe Harbor Freight.
Xantrex Freedom 458 feeding house batteries.
Going with 2ga stranded with 5/16 lugs finishing off with the sealant type heat shrink tubing.
Oh, on the heat shrink tubing, what size for 2ga with bell shaped lugs?
I noticed they also sell the little solder pellets but im sure crimp vs solder lugs would be another thread, subject.
I will have to google that one.
Thanks again for the reply's
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
