otrfun
Dec 24, 2022Explorer II
Rbertalotto wrote:How large is this 2a pad? I do know a single 25w (12v) 80x100mm silicone heating pad (which draws 2a) can get as hot as 160-170f. That's hot enough to burn your finger. Could be too hot for a plastic battery case. That's the primary reason why we used 4 of these same 25w heating pads wired in a parallel/series configuration. It distributes the same amount of heat as one 25w pad over a much larger area. With the 4, 25w pads wired parallel/series, each pad only heats to 110-120f (vs. 160-170f), and only draw 2a of total current (vs. 8a all wired in parallel).
Agree on the pad size. I bought a smaller, 2amp pad to try in the truck with the one battery to see how it works. Stay tuned!
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
