StirCrazy
Dec 28, 2022Moderator
Rbertalotto wrote:
DIY Battery Heaters...A REAL TEST!...got down to 7F degrees last night. At 7am the battery compartment is at 35 degrees. Controller is set to turn on at 35F and off at 38F........The batteries are at 90% on the monitor.....Working GREAT!... http://rvbprecision.com/rv-projects/lithium-battery-heating-project.html
well done, but like others I question the wattage of the heater. if you went with a hard sided rotomolded cooler you could probably get away with even less wattage, as the usage of the battery would probably generate enough internal heat to keep it good and your pads would only be a back up. but you do sacrafice a bit of portability that way.
Steve
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
