MEXICOWANDERER
Dec 06, 2014Explorer
What kind of motor vehicle? Need to know so as to figure out if the stator laminations are accessible.
The rectifiers and regulator are the most thermally sensitive components. I do not like to see rectifiers at temperatures higher than 110C, and voltage regulators greater than 70C
Derating of devices becomes stupidly intense at these temperatures.
If you can THERMAL EPOXY a thermocouple direct to the stator laminations, that is a good area. Thermal epoxy like ARCTIC SILVER works good. Scuff-up the bond-to surface good with 180-grit emery.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
