arcsum68's avatar
arcsum68
Oven Going Out / Thermocouple
Hey all.
Did some searching and found tons of posts where people have the same issue that I seem to be having where the oven will light perfectly fine and then go out. The general consensus seems to be that either the pilot light is not big enough, or the thermocouple is not in line with the flame and gets blown out when the main burner comes back on to bring the oven back up to set temp after the initial heating process. I looked and do not see any adjustments for the pilot light, and the flame and the thermocouple do appear to be in line with each other, though its difficult to tell and I am not sure just how perfect it needs to be.
I will take any advice, but I was wondering if the thermocouple itself could still be the problem. Do these things work intermittently? My trailer is a 2014, however it was only used a handful of times before I bought it and the oven looked like it had never been used. The fridge and thermostat still had the factory plastic protectors on them!
