Can't seem to nail this all down apples to apples when the goal posts keep shifting. :(
What's the story on this battery EG?
http://www.wegosolar.com/products.php?product=S6%252d460AGM-Surrette-AGM-Sealed-Battery-6V-400AHR-%40-20hrIt is 6v, 415AH (on its label), has a recommended 80amps and a max amps 140a on its label at about 14.6 when paired as 12v. Note that there IS a max amps.
So if that means the same at 12v using two of these ? does it?
then 80/415 = 19.3% charging rate, and 140/415 = 33.7% charging rate.(same as Prosine 2.0 says for deep cycle Floodeds)
My ugly graph was using 70 on 220 = 31.8% and could have been higher on those two 110AH Wet 27s.
I don't believe that it would be faster at a 33% rate to charge that pair of AGM 6s than on the same AH worth of Floodeds.
How can you speed up the time without increasing the charger amps?
Perhaps by extending the time in Bulk? But the examples seen show they are similar SOCs for when Bulk ends. So faster Absorption time after Bulk ends? Could be--I don't have any time numbers for how long it takes to get from 90-100 for either type of battery.
Mex wants to do "saturation charging" for fastest time. That means no Bulk, all Absorption with its tapering amps. If AGMs do absorption faster (maybe they do) he would see a faster AGM time there than with Wets. Maybe.
the issue is then how fast will amps taper to a lower amp and less costly charger size that can be run on a lower VA size generator and how many minutes of gen time will you save between saturation amps and getting down to the lower amps? Is that going to be worth it?
What does "worth it" mean? Mex wants to save Gen fuel because it is a hassle to get more fuel. I don't care about the fuel, cost or ease of getting more, but care about gen time to fit into "gen hours" as set by campground rules. Scenario is everything.
