pianotuna
May 05, 2016Nomad III
When it is fully charged (after each use).
A high enough voltage with a long enough charging period.
If the battery is not charged the sulfate becomes hardened and may be extremely difficult to remove--it might take an extremely high voltage to do so--perhaps even as high as 17 volts.
This all refers to the negative plates. The positive plates do erode (slightly) with each and every cycle.
red31 wrote:
When is a battery not sulfated?
What does it take to get all the sulfate back to it prior states?
When does it become irreversible?
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 11, 2026
