Veebyes
May 06, 2016Explorer II
If you double your battery bank capacity without doing something about increasing the charge rate of the charger you are going to double your charging time, both on the bulk & absorb charge time.
The only other thing you might consider is installing a multi bank battery switch & work between the 2 banks. The net charging time for both will be the same.
Battery bank size comes with weight too. There are choices to be made.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
