Golden_HVAC
Aug 16, 2014Explorer
The 12 volt things will work as long as the battery stays charged. However a CPAP can discharge 2 batteries overnight. So you will need to upgrade the batteries, and also consider a larger solar system in order to dry camp at all.
I installed a 400 watt solar system in a larger fifth wheel for a CPAP owner. He already had two batteries, and I installed 2 more. A 1,500 watt MSW inverter, new electrical panel, and transfer switch. This powered two of the 120 volt circuits in the RV.
He could run the CPAP overnight and that would run down all 4 batteries. In the daytime, he would use the solar system to recharge the batteries, then sometimes need to run the generator to fully charge the batteries.
Fred.
Fred.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
