wa8yxm
Aug 16, 2014Explorer III
Inverters are optional on most trailers.. Or you can have one installed "After market" as I did on my motor home.
For PAP use (C, Bi, Flex) if you can get a 12 volt model that is best as you loose a minimum of 10% running through the inverter.. But if yours is heated and humidified 12 volts might NOT be an option.
(I follow this stuff for friends, but my own sleep studies confirmed I do not need a PAP device)
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
