Lynnmor
May 30, 2017Explorer II
joebedford wrote:
Did you bolt in triangular gussets inside the frame?
No, when you think about it the current cross-members have little lateral strength and attaching gussets would be of little value.
Think about it this way; if you would work the spring hangers side to side with a very large adjustable wrench, that is what your suspension is doing.
When you mentioned the tabs on the top of the frame, you should have floor joists above the frame for support. The floor should give some help to the top of the I-beams and the added trusses will keep the bottom in location.
I have photos that I can link later if you want.
