joebedford
May 31, 2017Nomad III
myredracer wrote:I have the advantage of many more photos of the underbelly. I have not seen anywhere the floor touches the cross-beams. The floor seems to be entirely supported by the frame rails and the "wing extensions" that go about 10" outside of the frame rails - nothing in the middle.
You can't possibly have the OSB or plywood floor supported only on the I-beams and crossbeams.
The upper 5th wheel section of the RV has the square aluminum tubes under the floor like you describe but I see no signs of anything like that in the lower level.
The floor in the 5th section is OSB. The floor in the rest is foam core plywood skin. It probably has internal studs like the walls. Maybe that's why no external support?
The kitchen center island is on top of this section of floor. The fridge and stove are in a slide.
The garage has a couple of heavy beams but there's one section of floor with no external support. At least the fuel tanks have good support. I've never noticed any floor flex with one heavy bike and heavier trike in the garage.
