GordonThree
Jan 31, 2014Explorer
Almot wrote:
Have you tried them already? How is color temp - is it what it says? Are watts/amps where they should be? ... proper cover/diffuser and rocker switch. Strip are very narrow, about half inch, and need a diffuser to spread the light and avoid contrast shades
I snow-blowed a path to my TT door today, so I hope to fire up the furnace and spend some time in there this weekend.
The strips are warm-white, they look close to their advertised color, whiter than incandescent but still warmer than a "daylight" type LED. They came with a frosted diffuser, which does blend the individual LEDs after a few feet. I do concede your point, the plain aluminum strip is not a complete fixture and doesn't look as finished. Mine will be mounted under-cabinet, and I might put some wood trim along with them to dress it up a bit.
I haven't measured the current draw, I suppose I will dig out the multimeter and make sure they perform as advertised.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 14, 2026
