bobcouch's avatar
bobcouch
Dometic - Up or Down
Actually two questions...
We got flooded out of our house by Imelda, and will be living in our 5th wheel for the foreseeable future.
We have a brand new Dometic fridge that is running almost cool enough on max setting. I know moving the slide up or down the fins changes the temp, but I can't remember which way is which.
question 2 - I know it cools faster on propane, but should it maintain the temp I want on AC? Outside temps 80s to low 90s.
  • Up is colder, down warmer
    Get a snip the tip, and then you don’t have to worry about moving it
  • A new fridge should have the proper fin setting printed on the wall next to it.
  • lap527 wrote:
    hmmm.....we were always told that sliding it up meant colder. Inquiring minds sure would like to know. Would it matter what kind of rv refrigerator it is?
    OK, you are correct. I looked up a couple YouTube videos and "UP" is colder. Sorry, my bad.
    I guess I had the wire stretched to the max with the slide going up.
  • hmmm.....we were always told that sliding it up meant colder. Inquiring minds sure would like to know. Would it matter what kind of rv refrigerator it is?
  • Down = colder. Yes, should maintain on electric. Electric should take it down and hold it too.
    Although we no longer have a gas-electric refer, on all my 3 past TT's, electric always brought the freezer to -2 and the refer to about 36-38 when outside temps were in the 80's and 90's. I moved the temperature slide all the way to be bottom, as far as it would reach and just left it there. Never had a problem, and any time of year, under any conditions, the freezer was always -2.
  • You talking about your refrigerator or the a/c : air conditioner? I have yet to hear of running the a/c on propane. I understand that if you put a sun blocking shield over the side of the RV where the fridge vents that will help. Reflextrix should work well and you can get that at Lowes or Home Depot. Some people install a fan inside the fridge and/or behind it.
    For the a/c pull the cover off and clean the coils. Clean the filter inside.
    Generally most people think that the fridge cools down faster on electricity.
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 19, 2025
