slotsavegas's avatar
slotsavegas
Dometic 15K Duo-Therm Question
My A/C is having issues cooling properly. I frequently experience freezing of the coils. I took the inside cover off today and it appears the freeze sensor may be loose, and the coils appear to have some minor dust accumulation. I do not have enough clearance to access the coils from the inside. I want to reattach the freeze sensor as well as give the coils a good cleaning.
Does anyone know if both the outside coils and the inside coils can be accessed from the top of the RV after removing the cover.
Thanks for any help you can provide.
  • Everything is accessible from the top, after removing both the shroud and sheet metal or other housing (depending on model, etc.)
