northshore
Apr 19, 2015Explorer
Dometic 2652 Americana with problems
Ive got a '03 Wildcat 26 fbs with the Dometic fridge 2652 2 way operation.
First the unit works fine on electric no problems.
On gas it fires up,good flame and cools the unit fine, but shuts off after about 8+ hours. For example I can start the unit on gas in the morning, will cool fine all day, the next morning the flame is out with NO "check" on. I can shut the unit down, and it will fire right back up and operate for hours.
I changed the thermostat, no change, I cleaned the flue, no change
I know the electric gas valve is working, and I have plenty of LP gas and good batteries.
Ive got a couple of questions that I thought I knew the answer to, but maybe not.
Does this unit cycle, does the flame go out when it has cooled to acceptable temp and then fire up when it calls for more cooling?
or does the flame (burner) run continuously?
Any help would be greatly appreciated.
