jmtandem
Nov 20, 2014Explorer II
This is an FYI for those having problems figuring out why a refrigerator wont' keep cold. I purchased a new Tango TT in 2010 Model 276RBS. Refrigerator never seemed to work effectively on propane. Electric shore power just fine. Refrigerator problems started on first trip...Dometic 2652 RBX. Dry camping in Yellowstone in October all the ammonia/refrigerant leaked out into a pool of green liquid on the floor in front of the refrigerator. Waited several days for Erickson's RV in Coeur de'Alene, Id. to find a new unit and replace it under warranty. Highly recommend Erickson's RV. New unit continued to have problems keeping cold on propane. Riser vent clear, clean burner tube, clean orifice, flame looked normal and stayed lit. The next year another cooling unit gets replaced on the refrigerator under warranty. Three new refrigerators and all still not working properly. Freezer just barely staying below 32 degrees and refrigerator compartment in the high 40's low 50's most of the time. We are camping in cool weather either at the beach or in the mountains. This month we experience another episode of refrigerator not getting cold. Call Tango mfg. Pacific Coachworks and ask them about problem. It's all long out of warranty and nothing they can do. I ask Pacific Coachworks where is a good RV shop as we are new residents to N. San Diego County. They tell me Sterling RV in Lake Elsinore. Sterling diagnoses the problem and finds that a large open space above the refrigerator existed without a baffle to effectively vent the hot gasses from the propane combustion to the roof vent. So all along my refrigerator was trying to stay cool with about 6 cubic feet of hot air above the unit. Sterling installed a plywood piece flush with the back of the refrigerator to create a chimney effect to get the hot air up to the roof vent. Tested refrigerator for last three days on propane and freezer is minus 2 degrees and refrigerator is 34 degrees. Sterling tried to get Pacific Coachworks to help with the cost of repair but no luck. Pacific Coachworks claims the baffle was likely removed when Erickson's RV changed out the refrigerator the first time. I doubt it.....it was never there in the first place most likely. There were refrigerator problems from the very beginning. Pacific Coachworks makes a good TT and I get it that things can go wrong and something can be missed. You buy a new TT and expect there not to be a hidden design flaw. So, all can look proper with your refrigerator but it needs to be properly vented. Sorry for the long post but it took us 4 years to find someone to finally figure this out and maybe this info will save someone some troubleshooting time. A few suggested we install an additional fan or two behind the refrigerator.....zeroing in on the problem but not the root cause.
I don't understand why the first repair shop tech did not notice the problem when replacing the refer. But, even if that shop (that you indicated did a great job???) did not see it, the second should have. What a path you had to take to get some help!
PCW changed ownership around 2010 and that may be when your unit slipped through the cracks as to the baffle. Lots of things going in with PCW at that time. Except a new set of tires, mine has been trouble free. You might want to invest a few dollars in the Dexter EZ flex and greasable bushings for the suspension. It is money well spent. My plastic OEM (or whatever they are) bushings were already showing wear at 4000 miles when I changed mine out. Otherwise they are a very well built and solid coach.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
