billyray50
Jul 07, 2017Explorer
Dometic Fridge not cooling properly on LP mode
Recently my Dometic fridge model DMR 702 has not been cooling at the same temps as on AC mode. It was manufactured in 2013 for 2014. AC mode the fridge temp is between 36 and 38 degrees. Freezer at 0 degrees. On LP fridge temps are around for 47 with high reading at 53 later in day. Daytime temps have been averaging between 79 to 82 degrees with average humidity here in upstate New York.
Things I did was to check the fridge pilot, burner assembly, and 12 volt fan. All seemed to be working fine.
