Old-Biscuit
Nov 20, 2014Explorer III
Mvpmich wrote:
I had a similar problem and it took four attempts and two units over two years to get it right. Most of the time if the fridge vents through the roof there isn't a problem. Mine was in a slide out and vented out the side via a top vent. It took the installation of fans pulling the air out at the top vent and a curved baffle at the top of the chase to prevent hot air from accumulating at the top of the chase. Not a pleasant experience. Glad your was finally solved.
And that was due to RV mfg. failing to follow installation requirements supplied & recommended by fridge mfg.
One only needs to look in the fridge mfg. service manual to find clearance, fan and baffle requirements. Information that is readily available
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
