pcorrell
Nov 09, 2023Explorer
I found the GAS PIPE running from the valve to the burner and the orifice were both clogged, and no gas could flow. I ran a piece of wire through the tube and tested by blowing in one end. You will need to remove the unit from the RV by loosening the four locking screws under the glass cover 1/2 turn. Disconnect the gas line, (shut off the gas valve first!), the 12v cables, and the ground wire and place the unit face down on a padded surface.
Related Content
- Feb 01, 2026Community Alumni
