dougrainer
Mar 31, 2020Nomad
You do not have a Penguin model. What did you tape off?????? Did you actually see the Phone type quick connects? If you have 2 AC units, either one can cause your problem with communication. The phone type cable usually goes from the Zone 1 Roof AC to the Wall tstat. Then there is a phone type cable going from the Zone 1 to the Zone 2 control board. On motorhomes Zone 1 is the front AC. On 5th wheel's the Zone 1 will be where the Living room is located. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
