H2oclass1's avatar
H2oclass1
Dometic AC freezing up
My Dometic AC keeps freezing up. The freeze sensor reads 74° all the time, so I replaced the sensor. The new sensor never goes below 73°. I don’t think it would be low on freon or the freeze sensor would indicate that. Any ideas on what I should do next?
  • Compressor relay probably sticking or stuck due to the bad freeze sensor.
  • 1. There is NO freeze sensor in the condenser.
    2. The Freeze sensor is mounted in the evaporator coil.
    3. What Year Brand Model RV?
    4. What Model AC and what TYPE wall tstat?
    5. HOW are you reading the Freeze Thermister temp? Doug
  • I agree the control box is malfunctioning if the freeze sensor is buried in ice is interpreted as 74/73F.
  • There are some trouble-shooting manuals on-line that may help you.
    I assume the freeze sensor goes to a control board that controls the compressor, etc. The next step is probably to trouble-shoot or replace the control board.
  • In the same place I took out the old one, in the condenser.
    Or in this case in the ice. :)
Having RV issues? Connect with others who have been in your shoes.24,347 PostsLatest Activity: Jan 10, 2026
