pjw73nh's avatar
pjw73nh
Dometic RM2453. LP good, AC freezes, nothing on DC.
Dometic RM2453. Works fine on LP, freezes on AC and does not appear to do any cooling on DC. I know from what the previous owner told me that the AC heater was replaced last year.
I am using the following diagram for troubleshooting.I am also using the Dometic troubleshooting manual.
Schematic
I am just getting around to writing this now. But based on my observations from the summer (and if I remember them correctly), the fridge operates as mentioned above.
I am pretty sure I have a shorted thermostat but would like a second opinion. Not only is the part quite expensive, but being installed a Roadtrek, this fridge is a real PITA to remove to gain access to the thermostat. If in fact, I need to remove to to get to the thermostat.
It's rather cold up here in the northeast today (11/11/2-17), but I figured it's a good environment to test for a thermostat short, because if anything, it would be too cold and the thermostat would be satisfied (open). I made two sets of tests today.
The first set was done with the inside of the fridge at about 25 deg F. Then I turned to fridge on AC for a few hours and brought the inside temp down to 5 deg F and did the second round.
Outdoor ambient is around 35 deg F, internal fridge (not freezer) temp is about 25 deg F. In AC mode, with the thermostat knob all the way counterclockwise (off) with an inductive clamp-on ammeter directly on the AC heater lead, I measure 1.5 amps flowing to the AC heater. Turning the thermostat knob full on makes no difference in current flow. Turning the selector switch from AC to off reduces current flow to 0 amps as expected.
Performing the same test with the same environmental conditions but in DC mode and measuring the DC heater, yields similar results. The only difference is that the current flow when on DC is 15 amps. Again, the thermostat control has no effect and switching the mode selector from DC to off kills all current flow to the DC heater.
As mentioned, I repeated these same procedures with the internal fridge temp at 5 Deg F and I received the exact same results. The current NEVER stops flowing to the heaters in either mode at either internal fridge temp.
If I recall correctly from the summer, gas operation works properly.
I don't see any schematic information for the gas operation. The manual mentions that the thermostat is "calibrated by the manufacturer to maintain a 40 deg temp" in the fridge. But at the same time it says that temp can be controlled by the thermostat when is gas mode. What is the mechanism that turns the flame on for cooling, and off for pilot (standby/bypass) operation?
Summarizing my issue:
1. Does it sound like a defective thermostat? Do they go bad? Often? In 30 years of RVing, in 6 different rigs, I've never had one go bad. From the schematic, I can't see it being anything else.
2. If it IS the thermostat, is there any means of accessing it without removing the fridge? What about the little capillary sensor? How is that routed into the fridge?
3. Why might it not cool on DC mode, when in fact, there's current flow? I am thinking when they replaced the AC heater, they might have mis-positioned the DC heater, and it just doesn't get close enough to the boiler for effective heat transfer.
Any thoughts or suggestions welcome.
Thanks.
P.../NH
