Ron_Nielson
Jun 20, 2014Explorer
The thermostat tells the A/C unit to run or shut off. If the thermostat tells the A/C unit to run, and it DOES NOT RUN, the problem is likely with the a/c unit. HOWEVER it it most likely a bad thermostat. Incorrect wiring between the thermostat and the a/c unit is always a possibility.
My suggestion is to replace your thermostat with a cheap digital model from WM or similar source for about $20. Digital thermostats control the temp much more closely than other thermostats. Lots of information about digital thermostats if you search.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
