dougrainer
Jun 21, 2014Nomad
Brandon327 wrote:
The thermostat is the dometic digital and this is the third thermostat that has been put in. Can't use one of the cheap $20 units because of the way it is wired with the control board in the ac unit.
It is NOT Dometic's fault. It is where the OEM mounted the wall tstat. You are trying to get too specific on the actual set temp. If you could install a $20 tstat, you would have the same problem, as that tstat would be sensing the air in the same area. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
