mileshuff
Sep 25, 2014Explorer
Bobbo wrote:
Not to berate the obvious, but you DO have your house battery connected, right? If you use the battery disconnect switch, you lose the 12v to the thermostat as well as most everything else.
Yes, that would cause many other items to not function if running on battery. This is while fully hooked up, battery connected too.
