SoundGuy
Jul 09, 2018Explorer
RobWNY wrote:
The fan works fine. I had the unit on for hours the next day and had no issues. It just went out in the night when it was very warm and humid and I had the fan on the low setting. The Ac is a Dometic Brisk II Air 13,500 BTU Rooftop Air Conditioner. The Thermostat is the Dometic CT Single Zone Thermostat.
I have the same unit but mine is direct blow with the thermo as part of the ceiling unit so as I indicated previously I'd suspect the issue is with your wall thermostat as the A/C will only do what it's directed to do by the thermo. According to your Owner's Manual this thermostat does have a Freeze Sensor (as indicated by error code E5) so perhaps it just did what it's supposed to do - shut down the unit until it defrosts, which in turn would explain why it worked just fine the next day.
Related Content
- Feb 01, 2026Community Alumni
