Old-Biscuit
Jun 01, 2015Explorer III
filthy beast wrote:
This past week while camping our fridge kept getting colder. I tried sliding the thermistor down (warmer) to stop this. That is when I noticed that the thermistor did not move with the clip. When I pushed it back into the clip the temp increased and stabilized. Unfortunately it would continue to creep up. I am going to contact Dometic and try to find out where in the clip the thermistor should be and glue it into that position.
IF you glue it then that is it.........no adjustment at all.
Dometic is going to tell you......
Tip (bulb) of thermistor should just stick out of top of clip
Clip should go on far right fin...mid position
Then after 24 hrs.....check food section temps.
Adjust thermistor as needed>>>>>>>>>>>>>
BUT they will NOT tell you to glue clip in place
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
