dougrainer
Jun 02, 2015Nomad
Moving the Thermister will ONLY change the temp in the refer about 4 degrees. So, IF you do not like the preset of 38 degrees. Moving to get it colder will only result in about a drop to 34/35 degrees. The adjustment on a Auto Temp Dometic does not change the temp that much. So, if the refer is sub 33 degrees, then you have a control problem(usually bad Thermister), not an adjustment problem. Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
