j-d
Jun 02, 2015Explorer II
An OPEN thermistor circuit will cause the system to run full time. I was testing one. Thermistor checked OK. That's somewhere in the range of 30K-Ohms with the tip in an ice/water bath approximating 32-degrees. Anyhow, checked OK but I accidentally fixed it. There was corrosion the connection between thermistor connector and control board (under a cover on the back/outside of the fridge). Might just look for that, unplug and re-plug.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
