dougrainer
Jul 29, 2015Nomad
tedp wrote:
Replaced my thermistor with the snip-the-tip and I still have the same problem (sometimes). When the motor home is parked in the yard I've run the refrigerator for days on gas or electric and it holds rock steady. As soon as I travel it starts freezing stuff again. Could it be that when the coach isn't level for sometime that the unit goes on constant run? Do I have to replace the circut board?
NO, There is no such feature or features on a Norcold or Dometic refer. When traveling, the units will sometimes cool BETTER due to the fresh air flowing in and out and the rocking of the refer while in transit. The Freeze Thermister just senses the temp and sends the signal to the control board to start the refer on and off. Doug
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
