tedp
Aug 09, 2015Explorer
dougrainer wrote:tedp wrote:
Well after further checking I found that when I put items on the top shelf it will start freezin stuff. This is driving me crazy. Now what?
The top shelf is next to the COLDEST part of the refer. The Evaporator fins. The Fins are 10 degrees colder than the temp in the refer. So, that means that area is sub 32 degrees, probably in the 22 to 26 degree range. So, the odds are some items will freeze if they are close to those Fins. What is the temp below the top shelf? Do items freeze there? Doug
Top & bottom both freeze. I'm thinking I'll have to change out the control board. Don't know of any other potential fixes.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
