Sep 03, 2021Explorer II
mileshuff wrote:It's common for the material the LEDs are encased in to fade and become discolored with age. This can cause them to emit less light. Does your strip look old, cloudy and discolored compared to new?
Is it common for led strips to become dimmer with age rather than individual leds completely fail?
The problem could be low voltage caused by a poor connection. You could measure the voltage across the two exposed wires. It should measure close to battery voltage.
New Dometic brand strip is $99 on Amazon but I see numerous odd brand strips for as little as $20. Any of the cheap strips good?I recently installed THIS STRIP. They are encased in silicone, which should help prevent age discoloration. They were easy to install and look great, but maybe a bit too bright.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
