dougrainer
Oct 11, 2015Nomad
Chris Bryant wrote:
That's sounding like RF interference. Do you have any florescent or LED lights? If so, try turning them off.
Chris, According to both Dometic and RVP, they have built in suppressors now for RF/Ripple problems. I think it points to a BAD RJ45 just as you stated. Resets NEVER, NEVER, fix this type problem. AS you stated it has to be the Cable or the RJ 45 connectors. On the OP's system that can mean up to 4 or more RJ45 connectors that DRV made. The wiring is NOT Dometic but the OEM makes and installs their own connectors and phone type cables. Turning the Power(120 or 12 volt) OFF and waiting and then turning it back ON also does NOTHING for this type problem. One bad connection on the communication cables will mess up the whole system. ALL phone type connections at both AC's and the wall tstat need verified. Doug
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
